I’m trying to connect multiple tees connections between existing pipes. I have managed to get it to work with two of the three pipes, but struggling to get all the pipes to connect. Can anyone assist? Here is a screenshot of my graph thus far.
As a new user I could not upload a screen shot of the pipes (can only upload a single file).
look forward to receiving constructive comments.
Here is a copy of the pipes.
I think there is no point on creating a dynamo graph for that end.
You can use the Trim/Extende Multiple Elements comand:
First you select the main branch with a single click then you can select all of the secondary branchs and it will create all the tees for you
there isnt a need to repeat the main branch 3 time. just feed it as per normal. it should work as i have been using this node
sort branch pipe
pipe1.point.y >pipe2.point.y>pipe3.point.y
something could probably work…
