Hello
im looking to replace two nodes one from chynamo and another from ampersand, with OOTB nodes/workflow (I hope this is within the guidelines of the forum):
the one from chynamo:
this one picks the element/element type by an ID (is there really no OOTB replacement?)
the other one is:
These should do the trick:
Element By Id is fairly old and I believe that all supported builds have it.
PolyCurve.ByGroupedCurves may not exist for you (guessing you’re in Dynamo for Revit 2.6 and Revit 2021), in which case you’ll need to use a GroupCurves method (Archi-Lab has a custom node for this, or you can utilize some Python or DesignScript which has been posted a few places on the forum) to group the curves into pairs before using a PolyCurve.ByJoinedCurves node.
Thank you so much for your reply.
element by id works perfect.
i cant find the bygroupedcurves, im using R2022:
Looks like you need a update for Revit 2022.
If the node isn’t there after updating Revit, proceed with the group curves and polycurve creation method I noted above.
