Revit 2024 Dynamo no Longer Has Revit.Elements.Parameter.Group Node
Background: I have searched for this topic and could not find a similar issue. Also I am very new to Dynamo. My Revit 2024 Dynamo build is v2.19.3.
When using Revit 2022 Dynamo build v2.12.1, we have a graph (written by others) which has a node that queries the Revit.Elements.Parameter.Group and passes that string value on to a DSCore.String.Contains node.
In Revit 2024 there is no node for Revit.Elements.Parameter.Group but there is a node for Revit.Elements.Parameter.GroupType. Therefore my node has the broken link icon.
What recommendation do you have for replacing my broken node in my Revit 2024 Dynamo graph? See the attached snip of the graph in Revit 2022 Dynamo v2.12.1 build so that you can see what it was doing.
For further info, this is how that same node appears in my Revit 2024 Dynamo build v2.19.3.
I have determined the problem and the script is now running properly. We replaced GlobalParameter.Name with String from Object and corrected the Code Block search parameter.
