Hi to all.
I am a new in Dynamo and at the moment I try to read, understand and learn the basics. I have a situation on creating the exercise from chapter 8 Dynamo for Revit (8.2 Selecting). As you can see from the picture from the book tutorial the node FamilyInstance.Symbol is used, but in the attached file - Selecting.dyn which can be found at the beginning of this exercise, a different node is used - FamilyInstance.Type.
After I opened an older version (1.3.3) I noticed that the node FamilyInstance.Type exist, but the node FamilyInstance.Symbol does not. In the latest version (2.0.1), which I use, none of the nodes listed above are to be found.
Could you please give me a solution to my situation?
Thank you in advance for your support and have a nice day to all.
