About familyInstance.Symbol node
Hi!
I’m a newer in Dynamo and learning Dynamo in The Dynamo Primer. Now I have a problem about the familyInstance.Symbol node. I can’t find it that I did the exercise in Chapter 8.
What’s wrong in my learning?
Thank you!
Hello DEARTOTORO,
I will come back to you why it is not showing up now.
Now now you can acheive the same results using “Family Types” node.
From the drop down you can select the family type and then connect that node to “All Elements of Family Type”.
Hope this will help.
Thanks,
Ritesh
