Hello all,
I cannot see the result of the node in the bottom box. I only got the message that ‘No replication guide will be added’
I already restarted both Dynamo and Revit but the problem remains.
Do you have any idea?
Thank you in advance!
Hello all,
Hello all,
I still have the same problem with the message 'No replication guide will be added’. I open different projects and start dynamo from scratch or some existing scripts that I had, but the problem remains.
Any idea?
Thank you!
I also see that the Lacing options when a do a right-click in the workspace are grey out. Do you have any idea ?
Thank you
Hello @sovitek ,
Revit : 2021.1 and Dynamo Core : 2.6.1.8786 , Dynamo Revit : 2.6.1.8850 , it says that it is ‘up to date’.
thank you
have you tried open a new blank dyn …and copy the graph over there ?
yes the problem remains. I have also restarted Revit/dynamo but I have the same results…
I checked it also in empty projects, and in projects that I have Revit geometry, but same thing
Here is a part of a file that the problem appears :
test.dyn (14.0 KB)
