import sys
sys. path.append("C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.10_3.10.1776.0_x64__qbz5n2kfra8p0\Lib")
import math
clr.AddReference('RevitAPI')
clr.AddReference('System')
# Preparing input from dynamo to Revit
![1|690x411](upload://k2tL8U6VcRJD10VzqmGMer7igNA.png)
wallNames = []
wallAreas = []
wallVolumes = []
wallLengths = []
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType()
for c in collector:
wallNames.append(c.Name)
Area = c.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsDouble()
wallAreas.append(c.Area)
Volume = c.get_Parameter(BuiltInParameter.HOST_VOLUME_COMPUTED).AsDouble()
wallVolumes.append(c.Volume)
Length = c.get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH).AsDouble() * 0.3048
wallLengths.append(c.Length)
OUT = wallNames, wallAreas, wallVolumes, wallLengths
I have this code but I don’t know why I get this error “Wall Object has no Area attribute”
The first line is great. You get the area via get_Parameter
and then assigning it to the variable Area
The second line is the issue. You have the area but then you try to pull it again as a property of c
, which is not a valid attribute. You just need to append the value you already have, Area
Right now you’re essentially doing the same thing twice. Once in the correct way and once in the incorrect way. You just happen to be using the incorrect way to build your list.
Now on the same code, I get this error for the length
import sys
sys.path.append("C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.10_3.10.1776.0_x64__qbz5n2kfra8p0\Lib")
import math
# Preparing input from dynamo to revit
wallNames = []
wallAreas = []
wallVolumes = []
wallLengths = []
for c in collector:
Area = c.get_Parameter(BuiltInParameter.HOST_AREA_COMPUTED).AsValueString()
wallAreas.append(Area)
Volume = c.get_Parameter(BuiltInParameter.HOST_VOLUME_COMPUTED).AsValueString()
wallVolumes.append(Volume)
wallLengths.append(Length)
OUT = wallNames, wallAreas, wallVolumes,wallLengths
I can understand what is the problem here
As far as I can tell their is no issue, works for me. Try in the basic sample model, it gave me all the values there.
