Hi @Dongzi,
Why don’t to try to add an element to your node IN[0]?
clr.AddReference("RevitAPI")
elems = UnwrapElement(IN[0])
OUT = elems
@Dongzi it is working from my side with CPython3; Can you share your DYN file?
Question.dyn (3.2 KB)
hi, there is only PythonScript here, but it still reports an error, can you see why?
@Dongzi I downloaded the dyn file. didn’t give any error.
@Dongzi your file is working from my side as well, I think you need to install Python 3. on your machine.
I installed Python 3.8.3, and everything else runs normally. Excuse me, is your Dynamo version up to date? Revit2022 version used?
I am using Revit 2022 Dynamo 2.12.0
I am using Revit2021, and then upgraded Dynamo to 2.10, will it be the reason for my upgrade.I’m using the cracked version. . The original is too expensive. . . .
hello @Dongzi
any reference to cracked software versions is prohibited on this forum.
CPython3 engine is not available before Revit 2022, this topic will be closed
Note:
if you are a student, try to apply for an educational license of Revit ![]()
