'Wall' object has no attribute 'Faces'
Hello. I am new to using revit api in python. One of the points I do not understand is that the walls I list with Filtered Element Collector do not have Faces attribute. But the walls I listed from Dynamo have the Faces attribute. Both wall_element_lists have the same IDs. Can you help me?
import math
clr.AddReference('RevitAPI')
import Autodesk.DesignScript.Geometry as DSG
dataEnteringNode = IN
# Place your code below this line
all_wall_element_list = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
wall_element_list = []
for wall_element in all_wall_element_list:
    if getattr(wall_element, "CurtainGrid", None) == None:
        wall_element_list.append(wall_element)
faces_list = [wall.Faces for wall in wall_element_list]
OUT = faces_list
The “Faces” attribute is associated to the Dynamo object, not the Revit one.
The content gathered with a filtered element collector is pulled as a Revit element, while the content gathered by a AllElementsOfCategory node is a Dynamo reference to a Revit Element. The former is direct access to the full Revit API, while the later is just what Dynamo has a wrapper for - be they indirect Revit API calls or Dynamo specific API calls. Element.Faces is a Dynamo specific one, and as such is not available on the native Revit API.
Look into the getting the geometry in the native Revit API if you want to use the filtered element collector, as shown here: Geometry Property
Note that you’ll have to extract the surfaces from the solid once attained.
Thank you for the explanation. I only know the way to access the surfaces from the dynamo reference. Is there a way to wrap it to access the dynamo reference? Or is there a way to access all surfaces from the Revit reference? Sorry I’m trying to read the API but it seems a bit strange for me at the moment.
I found a way “ToDSType(element)”.
Yes, that will work. Generally speaking g though you’re better off staying in the Revit API once you go there. You’re adding a new dependency and it’s a slow conversion. While it might not feel that way yet - trust me on this one the bouncing back and forth between libraries is a killer.
What have you tried in the Revit API context?
Thank you for explanation. I am using Filtered Element Collector, Room Boundary Segments, element parameter works. I have to use ProtoType() because I can’t do simple geometry operations like 3D Boolean operations, Element surfaces and Curve extrude.
Sure can - there is an entire class called BooleanOperationUtilities to help with this. BooleanOperationsUtils Class
These are extracted from the solid in both the Dynamo node and the Revit API, Dynamo just hides a step. This is the Revit API call. Faces Property
Also doable: CreateExtrusionGeometry Method (IList(CurveLoop), XYZ, Double)
Or maybe you want this: CreateLoftGeometry Method
Hard to see without seeing your code.
these are great guides, thank you :slight_smile:
