How to create dynamo-geometry?
i want to create solids (dynamo) in python… need i a library for that? final aim is union all geometry to one
clr.AddReference('RevitAPI')
clr.AddReference('System')
collectorColumns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns)
placedColumns = collectorColumns.WhereElementIsNotElementType().ToElements()
#var options = new Options() { ComputeReferences = true, IncludeNonVisibleObjects = true };
#var geometry = placedColums.get_Geometry(options);
geoms = []
for i in placedColumns:
	geoms.append(i.GetSymbolGeometry())
OUT = geoms
You’ll need to use the standard Dynamo geometry library to access the Dynamo geometry tools. These lines should do the trick:
@jacob.small ,
it does still not work, the method does not exist
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
geoms = []
OUT = geoms
you need to convert the objects, here are 2 solutions:
  • the first by converting a Revit object (wrap into a Dynamo Revit.Element object )
  • the second by converting the geometries
import sys
geomsA = []
geomsB = []
opt = Options()
	# Solution 1
	geomsA.append(i.ToDSType(True).Geometry())
	# Solution 2
	geoset = i.get_Geometry(opt)
	for geo in geoset:
		if isinstance(geo, DB.Solid) and geo.Volume > 0:
			geomsB.append(geo.ToProtoType())
		elif isinstance(geo, DB.GeometryInstance):
			for geoi in geo.GetInstanceGeometry():
				if isinstance(geoi, DB.Solid)  and geoi.Volume > 0:
					geomsB.append(geoi.ToProtoType())
OUT = geomsA, geomsB
@c.poupin ,
thanks, i got following warning… how can i solve that?
grafik
i choose columns because i think thats the simplest geometry
try to change the geometry scale
all 4 option do not work :confused: @c.poupin
with basic nodes i see “something” with the same error
intresting when i play with scales the error changes …
grafik
It’s a bug on some geometries
if the goal is only visualization, you may be able to extract only the surfaces rather than the complete geometry
@c.poupin ,
the goal is i want to compare two modells by geometry independed from categories.
i have also to make union of all categories to get this single concrete geometry!
f. e. Model (ARC) has a Volume from 200.000m³ and Model STATIK has a Volume from 201.000m³
so i can see it has a delta from 5.0 %
i see in my project the Planers have different model-rules but come to the same result. i want to say the model is fine inspite of the different “modelstyles”!
thats the aim
I think that the only solution will be to work only with native geometries of the Revit API (no conversion).
Or need to isolate elements that cause this bug (but the result may be wrong depending on the volume of this element).
@c.poupin ,
so it is not Element.Geometry :wink: it should be Element.NativeGeometry …hmmm
i need just the “shell” of the concrete building… it sounds easy
visualisation is no issue in outer softwares, but to get the volume of a shell is the challange
Usually if you convert this kind of things to dynamo geometry, it will contain error.
For me I will stick with revit geometry.
and you can check is there solid in your object by using revit lookup:
here shows there is solid inside this wall.
Then use revitapi to extract its geometry.
@newshunhk ,
for system families it works for one instance
import sys
elements = UnwrapElement(IN[0])
geom = elements.get_Geometry(Options())
for g in geom:
    if isinstance(g,Solid):
        solid = g
OUT = solid.ToProtoType()
How to i interate true my elements?
solids = []
truesolids = []
for i in elements:
	solids.append(i.get_Geometry(Options()))
for g in solids:
        truesolids.append(g)
    	pass
OUT = truesolids.ToProtoType()
my code is a pit off
you can add this in your code:
toList = lambda x : x if hasattr(x, '__iter__') else [x]
elements = toList(UnwrapElement(IN[0]))
this will turn your element into list if it is not a list
toList = lambda x: x if hasattr(x, '__iter__') else [x]
solids = []
for i in elements:
    geo = i.get_Geometry(Options())
    for g in geo:
        if isinstance(g, Solid):
            solids.append(g.ToProtoType())
OUT = solids
@newshunhk
from where do you get this methode ? it is not exposed to the revit API ?
@newshunhk ,
it works in the demo… in the real project it has difficulties to create the solids… :frowning:
it says like curves “branching” …
grafik
grafik
how to get rid of that?
Post the full code, including imports when trouble shooting like this.
import sys
solids = []
for i in elements:
    for g in geo:
OUT = solids
Converting to a Dynamo solid isn’t always possible as the geometry tolerances of the two tools aren’t possible. Best to keep to Revit geometry as noted before, removing the need for the ToProtoType line.
See if it works when that is removed.
@jacob.small ,
the imports will be the static categories
  • beams
  • slabs
  • walls
  • columns
