Very new to Dynamo and my only programming experience is with C#. Any help would be appreciated.
I have two lists of strings; one is a list of the names of the StructuralFraming members from the model and the other is a list of the members I want to keep. Programming through the API this would simply be a nested foreach loop to test each value in the names list against all the values in the test list. Like this (I’ll call the lists Names and Test):
foreach (string x in Names)
foreach (string y in Test)
if (x==y)
return true;
For the output I need a list matching the Names list in length that contains boolean values. I cannot figure out how to do this with the code blocks and there don’t appear to be any nodes that will do it either.
