How do I define the information I need for _tagLocations?
Every node looks good, have you make sure all the rooms are placed?
Also, it will be good to see the error in Element.GetLocation.
There error is:
Warning: Element.GetLocation operation failed.
The location of the structural element is not a valid curve.
I am attaching the graph here. 2.0.x hopefully you can give it a spin.
TAG ALL ROOMS.dyn (21.6 KB)
there is a node, called room.Location. I believe that is the node required instead of that
Could you switch on Room.Location preview and show values?
You must filter the unplaced rooms (area = 0).
@crullier Try changing lacing to longest-CreateAnnotationTag node.
Thank you, but that did not work. How are other folks using Dynamo to tag rooms?
I am so close yet so far.
