I’m trying to use Python to get the air terminals in a mechanical system, so I wrote this (probably flawed) script:
import sys
dataEnteringNode = IN
Input = UnwrapElement(IN[0])
app = uiapp.Application
resultOut = []
if isinstance(IN[0], list):
for mepSystem in Input:
resultOut.append(mepSystem.Elements)
resultOut.append(Input.Elements)
OUT = resultOut
My dynamo graph looks like this:
My question is:
Why does the output of the Python script display the element’s namespace? I’m expecting it to output the elements themselves.
Thanks for the info Deniz.
I’m getting this error though:
File “”, line 33, in
AttributeError: ‘ElementSet’ object has no attribute ‘ToDSType’
The node is outputting a null after changing the code as follows:
import sys
resultOut = []
resultOut.append(mepSystem.Elements.ToDSType(True))
resultOut.append(Input.Elements.ToDSType(True))
OUT = resultOut
I looked up the ElementSet class in the API, but did not find any useful info there. I guess I’m confused about how to access the elements within the ElementSet instance.
@Frank_Loftus is this what you are looking for?
import sys
resultOut = []
for e in Input.Elements:
elem = e.Id
f = doc.GetElement(elem)
resultOut.append(f)
OUT = resultOut
Excellent! This works perfectly. Thank you @Elie.Trad!
I suppose my error was not using the “GetElement()” method.
