Hi new user of dynamo, I try to use dynamo in revit 2018 but the reference point I created in dynamo is not dynamically with revit nothing at all.
Hi @Iron.Max.Steel,
If you are new to this forum, I’d suggest you read the forum guideline in order to get the help you are after.
As a minimum, you should provide a screendump of what you’ve done so far.
Hi Martin,
Thank you for your suggestion.
Its okay now, I just need to zoom-in a lot my revit view to see the point moving dynamically with dynamo.
