Novice here. My Dynamo model is appearing in Revit but the parametric modifications I do in Dynamo are’nt happening in Revit. For example, the points I laid out in Dynamo with a number slider, move up and down accordingly. But once I transfer the point to Revit with a ‘Revit point by point node’ the point appears but is static and doesn’t move according to the parameters. It seems to me it is a compatibility issue. You can see from the image that the point in Dynamo is higher than that in Revit. Could some one enlighten me? Thanks.
you will need to post an example of your definition or at least some screen shots of desired output. In general just read this: How to get help on the Dynamo forums
