I have a revit component in which the component moves based on multipule parameters. In the image u can see that i did this by adding number sliders, to set the parameter value of each component.
However, I want to have all sliders locked together. So if i modify one slider, all sliders move between the minimum and maximum value alltogether at the same time.
Is there a solution for this? mabye i Python script or some other node?
I would define the ranges using code blocks, then use a single slider and code block to extract the values at the nearest index to a percentage along those sliders.
Also you might find this useful as a method for list splitting that only uses one code block vs. multiple item at index nodes… I use it all the time!
