MultipleInputForm++ - Listview Data Problem
Hi there,
my Listview Data doesn’t appear in the UI when I’m trying to use Data Shapes MultipleInputForm++ following a video tutorial.
Anyone knows what the problem is?
Here is an image of my nodes and the UI that it creates.
I’m using Revit 2022 and Dynamo Revit 2.10.1
That tutorial looks familiar :wink:
Hrm it all looks OK on paper… except, the label width is quite wide at 700 (and matches the width - might push it outside the UI?), so maybe try removing that input as it is optional, or make it quite small, like 150 or so. Keep the width at 700 though.
is that the latest DS version ?
Thank you so much Gavin, actually it was your tutorial I was following. I changed the width and it worked. Many thanks.
Yes it is the latest version
