Multipleinputform++ / Interface box dont shop up when i run my script
Hello. I have made this which is supposed to make the interface pop up, so that I can select which parameters will be excluded in my excel export. My problem is that the interface dont show up when i run my script… Do any of you dynamo gurus see any mistakes in the setup?
What I hope to get is a lot of different parameters which will be included, but the ones i click off should be removed afterwards.
Hi @LukasMadsen does that mean the radio doenst pop up ? which version are you in ? not sure datashapes work if in 25, but if you are in 23-24 then you will need ironpythonpackage 2.7 ver 2.5 installed as well…PS i have never tried with so many radio buttons before…not sure if there is some limit…becaurse all looks right
Even though I put only “Length” as a key it still does not work :confused:
This is Revit 24
hmmm dont think you will need a list create…and tou have the iron package installed
This one?
arhh try with version 2.5 for 23-24
Must be this one then?
yes exackly :wink:
Jesus Sovitek you are nothing less of a dynamo guru! Thank you for your help! :slight_smile:
cheers for your kind words…and nice to see projects in danish here on the forum…S
Now that it works is there any way that i can select more than one “radiobutton” at the time?
dont think so, becoarse then its not a radio botton more…but you could try list view data instead :wink: for select multiple
It seems like my script just runs and exports to excel, and only afterwards the interface shows up. And sometimes the interface dont even show up… Ever tried that before? :confused:
im not really sure what you mean…but if you are in dynamo and run…we need toogle on/off between run…you dont need that if you run from player…is it what you mean ? ps you are wlecome to pm me…if its some other thing and discuss in danish if it more easy
