The DATA-SHAPES MULTIPLEINPUTFORM ++ window is not visible
bonjour
désolé pour l’anglais.
le meme fichier *.dyn fonctionne sous revit 2023 mais pas sous REVIT 2024 - 2026.
la fenetre MULTIPLEINPUTFORM ++ ne semble pas vouloir s’afficher a l’écran pour faire la sélection.
( pourquoi je la vois en violet sous dynamo ?? )
merci
Good morning
Sorry for English.
The same file *.dyn works under Revit 2023 but not under Revit 2024 - 2026.
The multipleinputform ++ window does not seem to want to appear on the screen to make the selection.
(why do I see it in purple under Dynamo ??)
THANKS
0__OK__MODIFIER VALEUR NUMERIQUE PARAMETRE DANS MEME ENTITES.dyn (43,0 Ko)
Phil
Likely you have an IronPython2 version of Datashapes (not sure there is a CPython version or IronPython3 version), and haven’t installed the right IronPython2 package for your Revit release. It could also be that the Datahshapes UI is relying on things which .NET8 doesn’t permit (i.e. the global assembly cache), but I do not believe that is the case.
