Hi everyone, Federico here, I’ve got a question: is it possible to create a parametric surface based on points inputed inside Revit?
I try to explain: I need to create some surfaces that describes a figure, inputed by points… the problem is how can I export that surface inside Revit as an object?
Thanks to everyone
Hi Federico
There is a node called FamilyInstance.ByGeometry in the spring nodes package that’s pretty great for that.
Thank you very much. I’ll try it and send you my feedback
Hi! I’m trying to make it works and I wondering if it’s possible to have a “multiple vertices input” instead of many single points… Is that possible?
I mean an indefinite number of point input.
