Hi Need Help!!
I have surface that I have created in dynamo that I would like to present place it on the Revit Model. Currently couldn’t find any information on converting surfaces to familyinstances that could placed in the dynamo file. So I need help.
Thanks in Advance
Please create a separate post for the reference intersect or stuff. These are not directly related and as such the thread will be quite disjointed and future visitors will likely be very confused.
Hello @abishek12354 …try something here…
@abishek12354, the big issue here is that there isn’t a way to model a surface in the typical environment - hence @sovitek performing the extrusion. As such you might want to first decipher how you would achieve the desired result in the context of the user interface, and then you can look into automation possibilities via Dynamo.
