Multiple Point on the surface
I want to place Points on to the surface and they sholud be able to be moved to the left right bottom and top but should leave the surface.
But i am not able to delete the point over the surface
Hi @Luthiger and welcome here :wink: try"does it intersect and a filter bool mask
Hello after the geomerty intercest? I should put filterbybollmask?
Yeah mean something here
I still can’t remove or be able to not show them
guess just turn off all preview in your nodes except the output nodes
hi
cordially
christian.stan
I am now able to select them but how do I remove them?
I tried it with a boolean but it didn’t worked
you freeze your appearances on display and you use a watch after your IN of your filterbyboolmask
cordially
christian.stan
Thanks for your help
