I’ve been struggling for days because it doesn’t work with multiple points. When I have just one point selected, it works perfectly fine, but when I select multiple points, it doesn’t work. I’ve been told that I need to delve into the topic of lacing, and then I can solve the problem. I’ve watched enough videos and I think I understand it, but the issue is that I don’t know exactly what’s wrong with my setup or where to address it. I’m relatively new to Dynamo, and I’m trying to improve day by day. I would be very grateful if someone could help me, and I would appreciate it immensely.
Hi @patrick.ericson see here
Instead of selecting just one point, I want to be able to select multiple points, but when I try to do that, it doesnt work, i hope you could take a look.
Then I added the new surface to “Geometry.Intersect” to get intersection between that surface and the circles, because you couldn’t get a intersection between all surface and all circles
Unfortunately, it is not what I strive for. When you have marked only one point, you get a result in centimeters, approximately around 1.5 cm or 2 cm, depending on the situation, so the distance varies from one point to another.
However, when I tried to mark multiple points because I wanted to calculate the horizontal distance to the surface, the results for the points you mentioned somehow appear empty. To be honest, I’m not sure what the reason for this is.
It’s as if the point in front of the surface is projected onto the surface with the same height and the distance is determined perpendicular to my axis.
And when I use your solution, the distances are referenced to some surface, and as a result, the distances appear to be very large.
Oki, it makes it a little bit more clear because I couldn’t understand what you tried to commit from your pervious posts.
I will try to give it another try
