Multiple lines do not follow the topography - Geometry.Intersect don't work as expected?
Hello friends, few days earlier I’ve watched MARCELLO SGAMBELLURI talk on the ‘Creating property lines that follow topography’. In the below image, I drew two lines but the dynamo script only render first line that follow the topography. Would appreciate if someone explain how do I render the other line too so that it would also follow the topography. Thank you
Topography Line.dyn (33.2 KB)
Not at the pc at the monent, but you could also try the Curve.Project node. @Nick_Boyts demonstrated this here 2D line - to projected 3D road alignment
Thank you so much @Ewan_Opie. It worked : -)
