Continuing the discussion from Data-Shapes Multi Input UI and ModelChecker:
Here is the Dynamo file:
Model checker - All.dyn (29.5 KB)
@Archinecture Change "Lacing to Longest" for “List.IsEmpty” node:
Show me previews for the first half of the script.
Mmm… Interesting. I used Revit 2018 and it works fine from my side.
@Archinecture Make sure you connect only Geometry Items to Existing Items.
Sure, thank you.
This is the working file in case anyone needs it.
Model checker - All.dyn (31.3 KB)
Sometimes the packages get installed incorrectly, I would re-install them and see if that helps
