Mtext
How do you make a line return in mtext with the Civil3DToolKit in dynamo? I would like a new line in the MText.ByPointTextRotation node.
Just type a new line!
To add to that, if you want to add a break in a code block you can use \n
See example below.
you can also add in “” in a string by using \"
Hope this helps!
Perhaps this could be helpful aswell: Escape character - Wikipedia
Thank you Patrick !!!
This helps
