Create MText
Hi … I am trying to add my own python script node to create MText objects in Model Space.
The input is a list of Points (output of Points.ByCoordinates Node).
Result: Civil 3D Fatal Error. Operation is not valid due to the state of the object.
Python error warning: No method matches given arguments for OnExit
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
def create_mtext(pnts):
    ipnts = pnts
    global adoc
    result = False
    with adoc.LockDocument():
        with adoc.Database as db:
                # Place your code below
                bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
                ms = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
                for i in ipnts:
                    with MText() as mt:
                        mt.Location = i
                        mt.Height = 2.5
                        mt.Contents = 'HELLO!'
                        ms.UpgradeOpen()
                        ms.Add(mt)
                        ms.DowngradeOpen()
                        t.AddNewlyCreatedDBObject(mt,True)
                result = True
                # Commit before end transaction
                t.Commit()
    return result
if IN[0] == None:
    OUT = False
    OUT = create_mtext(IN[0])
You are already opening model space ForWrite, so there’s no need to UpgradeOpen() and DowngradeOpen() within the loop.
Thx … I removed those 2 lines … no impact on the error, still the same …
hi
if you use civil 2023 check
from
with
            btrID = bt.get_Item("*Model_Space")
            btr = t.GetObject(btrID, OpenMode.ForWrite)
and
you have points dynamo or point3d
thx … I am still using 2022 . … 2022.2
TRY
import sys
    ipnts = pnts
    global adoc
    result = False
                for i in ipnts:
                    with MText() as mt:
                        mt.Location = Point3d(i.X ,i.Y , i.Z )
                        mt.Height = 2.5
                        #ms.UpgradeOpen()
                        #ms.Add(mt)
                        #ms.DowngradeOpen()
                        ms.AppendEntity(mt)
                result = True
                t.Commit()
    return result
if IN[0] == None:
    OUT = False
Here is my very bad DYN - including the updated script you provided …
I was planning to script the MTEXT as I needed more MTEXT creation options
Since then … I have opted to use Text instead of MTEXT and all is working correctly.
Would be interesting to figure out what the problem is …
Thanks for your patience.
draw-grid-mtext-script.dyn (127.8 KB)
Hey!!! I had a chance to try C3D 2023 today … and this works!!! Thank You…
… I must have done some type errors … all ok now … working with 2022 as well …
