Hi All,
I have situation where there are a lot of section views in the model and its driving me nuts trying to locate mine on the plan and move them while modeling my pipes. How can I select my section view from a drop down list and have it move automatically to where I click on the floor plan? I don’t want my section view to change elevations or the visual style, I just want it to move where I click on the drawing.
Sorry I’m completely new to Dynamo and I’ve tried searching for plugins.
You’re help will be much appreciated!
Thank You
Maybe that could be done with Dynamo but I would keep it simple and just create a working view that shows only your sections.
I just use View Filters
in those situation
OR
Hide at scales coarser than
In combination my own work views or
use Temporary View Template
Hi @elton.williams and @bvs1982,
You’ve raised some excellent points, and I’ve utilized similar techniques in the past. In my BIM coordination process, I typically work within a sheet view with the ceiling plan overlaid to visualize both the lighting and ceiling grid. When using a working view, the ceiling grid isn’t visible, and creating a dedicated ceiling view often causes issues with the display of duct drops and rises, making them appear inverted. I’m looking for a more efficient solution, potentially through Dynamo, to streamline this process and save time.
