Hi everyone, I’ve been stuck on a issue with placing coordinates respective to Project Base Point. Please see the below attached image. The coordinates I’m getting are from internal origin. Now I would minus the project base point from internal origin but that would not be correct. since the values of project base point are with respect to the survey point, which is also at (0,0,0) but it’s a shared site. How do I get the distance from PBP to IO so that I can place coordinates with respect to the PBP. Hoping the issue is clear, I tried my best explaining the issue. english is not my first language. Thank you.
This is more of a Revit question.
Please review this post How to get help on the Dynamo forums
As you have noted there are three coordinate systems available - have you set your Spot Coordinate family to the correct Base?
Hi, I’m using dynamo to place coordinates and coordinate base is project base point. I want to move these coordinates (that I got with dynamo i.e. with respect to Internal Origin) with respect to PBP. Sorry I hope this is clear.
I was able to use node from Genius Loci to convert revit coordinates of PBP from revit coordinate system to WCS. I then subtracted WCS coordinates from revit coordinates and used those offset to move all my points.
