Modify LinkVisibity with Dynamo
Hi everyone,
I’m trying to do a script to modify link file’s visibility with Dynamo. I saw with the new API in Revit 2024 that it’s possible ?
I try first with Rhythm package but I got blocked, so I try to do a python script with the new Revit class for LinkVisibility but I don’t know how to match the argument for View.GetLinkOverrides…
clr.AddReference('RevitAPI')
clr.AddReference('System')
linkinstance = IN[0]
ViewType = []
for Views in linkinstance :
    ViewType.append(View.GetLinkOverrides(Views))
OUT =  linkinstance
Hi @guillaume.trang ,
Could you share the API Page where you found that it’s possible in Revit 2024 to change the link visibiliy?
Yes of course !
it seems for now it’s limited to defining a linked view.
here an example to set a Linked View
Edit : code update for all PythonEngine
import sys
import System
#import Revit API
#import Revit APIUI namespace
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class Form28(Form):
	def __init__(self, currentView):
		self._currView = currentView
		self._linktypes = FilteredElementCollector(doc).OfClass(DB.RevitLinkInstance).ToElements()
		self._lstLinkViews = []
		self.selectlinkTypeId = None
		self.selectlinkView = None
		self.lnkDoc = None
		self.InitializeComponent()
	def InitializeComponent(self):
		self._comboBoxLinkType = System.Windows.Forms.ComboBox()
		self._comboBoxLinkView = System.Windows.Forms.ComboBox()
		self._buttonOK = System.Windows.Forms.Button()
		self.SuspendLayout()
		# comboBoxLinkType
		self._comboBoxLinkType.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
		self._comboBoxLinkType.FormattingEnabled = True
		self._comboBoxLinkType.Location = System.Drawing.Point(12, 36)
		self._comboBoxLinkType.Name = "comboBoxLinkType"
		self._comboBoxLinkType.Size = System.Drawing.Size(299, 21)
		self._comboBoxLinkType.TabIndex = 0
		self._comboBoxLinkType.Items.AddRange(System.Array[System.Object](self._linktypes))
		self._comboBoxLinkType.DisplayMember = "Name"
		self._comboBoxLinkType.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList
		self._comboBoxLinkType.SelectedIndexChanged += self.ComboBoxLinkTypeSelectedIndexChanged
		# comboBoxLinkView
		self._comboBoxLinkView.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
		self._comboBoxLinkView.FormattingEnabled = True
		self._comboBoxLinkView.Location = System.Drawing.Point(12, 85)
		self._comboBoxLinkView.Name = "comboBoxLinkView"
		self._comboBoxLinkView.Size = System.Drawing.Size(299, 21)
		self._comboBoxLinkView.TabIndex = 0
		self._comboBoxLinkView.DisplayMember = "Name"
		self._comboBoxLinkView.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList
		self._comboBoxLinkView.SelectedIndexChanged += self.ComboBoxLinkViewSelectedIndexChanged
		# buttonOK
		self._buttonOK.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right
		self._buttonOK.Location = System.Drawing.Point(225, 138)
		self._buttonOK.Name = "buttonOK"
		self._buttonOK.Size = System.Drawing.Size(86, 29)
		self._buttonOK.TabIndex = 1
		self._buttonOK.Text = "OK"
		self._buttonOK.UseVisualStyleBackColor = True
		self._buttonOK.Click += self.ButtonOKClick
		# Form28
		self.ClientSize = System.Drawing.Size(323, 179)
		self.Controls.Add(self._buttonOK)
		self.Controls.Add(self._comboBoxLinkView)
		self.Controls.Add(self._comboBoxLinkType)
		self.Name = "Form28"
		self.Text = "Form28"
		self.ResumeLayout(False)
	def ComboBoxLinkTypeSelectedIndexChanged(self, sender, e):
		self.lnkDoc = sender.SelectedItem.GetLinkDocument()
		filterV= System.Predicate[System.Object](lambda x : x.ViewType == self._currView.ViewType\
															and x.GenLevel is not None\
															and x.GenLevel.Name == self._currView.GenLevel.Name)
		self._lstLinkViews = List[DB.Element](FilteredElementCollector(self.lnkDoc).OfClass(DB.View).ToElements()).FindAll(filterV)
		self._comboBoxLinkView.Items.Clear()
		self._comboBoxLinkView.Items.AddRange(System.Array[System.Object](list(self._lstLinkViews)))
		self.selectlinkTypeId = sender.SelectedItem.GetTypeId()
	def ButtonOKClick(self, sender, e):
		self.Close()
		self.Dispose()
	def ComboBoxLinkViewSelectedIndexChanged(self, sender, e):
		self.selectlinkView = sender.SelectedItem
activeView = doc.ActiveView
objForm = Form28(activeView)
objForm.ShowDialog()
link_ovg = RevitLinkGraphicsSettings()
link_ovg.LinkVisibilityType = LinkVisibility.ByLinkView
link_ovg.LinkedViewId = objForm.selectlinkView.Id
activeView.SetLinkOverrides(objForm.selectlinkTypeId, link_ovg)
# check if the linked View is apply
link_ovg_check = activeView.GetLinkOverrides(objForm.selectlinkTypeId)
select_lnk_viewName = objForm.lnkDoc.GetElement(link_ovg_check.LinkedViewId ).Name
OUT = select_lnk_viewName
Thanks for your reply.
It is what I try to do, so I ran your python script but I got this error…
And when I click to continue, I don’t have anything in the second selection
Capture
I’m not with PC but for a CPython3 compatibility you need to cast the list ‘self._lstLinkViews’ into a .Net ‘List[DB.Element]’
I will update the code later if necessary
code update for all PythonEngines in previous my post
