Turn on/off Link with the same Script
Hello everyone!
I’m trying to turn on and turn off a Revit Link with a Dynamo Script. I’m using 2 packages: GeniusLoci and Rhythm, the script function perfectly, but I have to change manually the Boolean node to True and False, There’s some way to change it each time that I run the script?
I was thinking in a For loop with Python, but I’ve never working with it.
Thanks for your help!!
clr.AddReference('RevitAPI')
clr.AddReference('System')
revitlinktypes=list()
linkcollector=FilteredElementCollector(doc).OfClass(RevitLinkInstance)
revitlinktypes=[]
for rli in linkcollector:
	rlt=doc.GetElement(rli.GetTypeId())
	revitlinktypes.append(rlt)
	TransactionManager.Instance.ForceCloseTransaction()
	rlt.Unload(None)
At least you can unload it… with this,… maybe there is a user to put in a boolean :slight_smile:
KR
Andreas
You could create a .csv-file in which you save the last run state, .i.e. “False”.
Then from this .csv-file you could import the text together with a NOT node to reverse the input.
You can check to see if an element is already hidden in a view. Just use the opposite of that state when you run the graph. That way if the element is hidden, show it. If the element is visible, hide it.
Hi, Nick… How i can to know If a element si visible or not in one View?
I can’t find one node that help me
Thank’s for yuor help!!
Rhythm has a node or you can use the API method IsHidden.
Thank’s for all Nick. I can to resolve the problem.
In this forum is the solution!
