Today I checked the Dynamo Builds page and don’t see a bunch of the .exe installers that used to be there, like DynamoInstall 2.0.3, 2.0.4, etc.
The only .exes available are super old versions.
Where did all the other installers go?
I’m guessing it’s because Dynamo is installed with Revit for all current versions of Revit now. Although I can’t say why 0.6 would remain, especially compared to something newer like 0.9 or 1.3.
We are looking into it, but this wasn’t an intended change.
As a workaround, if you want a certain build it should still be there:
I.e link for https://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall0.6.1.exe exists, but so should https://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall1.3.4.exe, or https://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall2.0.4.exe, they just not showing up.
This is not intended. Most likely, this is due to the 500 builds infomation limit on Amazon AWS S3. Because there are a lot of new daily builds, we have seen this case from time to time that the number of builds got overwhelming and hides some of the old builds. Will work on it and get back to you.
Updates: Access restored. I had to move some old daily builds into the archive bucket.
