I installed Dynamo 0.7.0 in Revit 2014.
The “Dynamo 0.7 Alpha” button appears in the add-ins ribbon, but when pressed nothing happens.
Are there any known conflicts with other Revit add-ins?
There is a known problem with the installer in daily builds since the 12th. The downloads currently available on the download page have been fixed to remove builds since then. If you want to use a daily build, use this installer:
http://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoDailyInstall20140611T1823.exe
Just keep in mind that there is an inherent risk associated with using the latest builds that aren’t “stable releases.” You get the latest, up-to-date stuff, but you may end up helping us find bugs
