Hi there,
I want insert familly type in revit
So, i use http://www.revitapidocs.com/2018.2/4a037d33-8251-2a50-5470-c98320e2faff.htm
But i hav not Structural Type, don’t know how to do without that
Does anyone know that ?
Hi there,
Hi could you post some more information please? A test rvt and your dyn?
There are many reasons why it wouldn’t work. I believe if you define your Structural Type as so…
Using the possibililities here…
http://www.revitapidocs.com/2018.2/0a0a3793-5fce-283d-4953-a137f5593db9.htm
It should solve one issue
Hope that helps,
Mark
Hey,
For some reason you have ignored my advice above?
If you want me to help properly, please provide a rvt and dyn.
You have fed Spaces into IN[3]? What did you hope that would do?
Spaces are not a Member of the Structure enumeration in the link I gave you, only…
Rather that using an input I believe you can just put:
,level[i],Structure.StructuralType.Column
And that will (probably!) work
The error message from the Python states that the List object has no attribute Structure. This sounds quite reasonable.
There may well be other issues
Hope that’s useful,
Mark
