Hi!
I’m trying to create a script that is supposed to place multiple elements from a parameter (number) and the coordinates of spaces in revit. Before using the “FamilyInstance.ByPointAndLevel” I need to make sure the script doesnt throw out all elements at once. Basically I want the user to use a schedule in Revit and specify the number of elements that is supposed to be created in the “space”.
Everything seems ok before the last “python script node”.
Python Code:
import sys
*from Autodesk.DesignScript.Geometry import **
dataEnteringNode = IN
nr = IN[0]
pts = IN[1]
out = []
for i, j in zip(nr, pts):
- _temp = *
- for k, l in zip(i, j):*
_temp.append(k* [l])* - out.append(_temp)*
OUT = out
I get this “Error message”:
“Object cannot be intepreded as an index”
Does anyone have any suggestions how I can fix this?
