When I use the Revit 2020 with Dynamo 2.3.0. The Outputs of “Connector.Location” , “Connector.Direction” are still “Null” or “none”. But the “MEP Connector Info+” works well.
Hello T-POVER,
Thank’s for your package. I don’t understant why it doesn’t work. I read all the posts before and perhaps it’s a version issue.
The ducts are created but the return is null so i can’t use the ducts after your node.
Hello T-POVER,
Thak’s for your Help : i tried with 2018 version and 2019…my Revit is 2019.2
It will give an empty list if the supplied pipe has no upstream components. Of course it could also be an error in the node, but I would need your Revit file for inspection to see if that is the case.
I want to create several new zones with Zone.NewZone and then rename them.
With Zone.NewZone I can only create one zone at a time (next number), but with Revit command Zone many zones.
After a pause (30 seconds …) a zone can be created again with Zone.NewZone.
Where is the mistake? What command must NewZone be completed with?
Hello! Thank’s a lot for your time. As I can see you did a great job! I have a question about “Element.ElectricalCircuit” node. Does it get circuit number of Electrical Equipment families?
If the electrical equipment family has an electrical connector then it probably does. If you need more help on the matter then it would be better to create a new topic.
