MEPOver MEP fitting by point and curve works only for One size
by point and curve.dyn (14.1 KB)
Hello everyone , here the issue is i used,Mep fitting by point and curve. but it works only for Dia 150 pipes. if i apply for other sizes it creates the fitting but not connecting. i feel, i tried some other pythons from our forum. may be it overwrite. but not sure and i have no idea about pythons .i attached script and picture. please help me on this. i tried so many ways but didn’t help me. i appreciate your support. thanks in advance.
We would need a test file to recreate the issue.
What happens when you manually place fittings on pipes of those sizes? Have you looked into the Python code at all to see if there are any issues with rounding or assumed sizes? I’m curious if your pipes and fittings use the same calculation or table for connector sizes.
if i place manually it is fine, but as you said i tried in some other file even 150mm dia also it breaks and it connect only on 100Dia. and i am blind on python scripts .i took some script from our forum as a trial. but i am not sure it happened because of that. i just assumed, because before it works fine for me. here i am attaching my file and some samples are there. can you please check and help me. thanks in advance
test file2.rvt (7.7 MB)
Hi @RANITH the good old name issue, try rename MEPCurve to ex. mepcurve in the input and save the node and see if could be better
thank you very much for your replay. my error gone after changing this. but my issue remains same. any solution for this, please look in to this. thank you.
later if you havent find a way im a little bit busy…but first do you have ironpython package 2.7 version 2.5 installed ?
Try as here and see if it could work…
Revit_wmsAn02vM4
Hottme.dyn (25.3 KB)
thankyou very much for the support. i already installed iron python 2.7 version 2.5..a small clarification, if i have two pipes with different system type and two list of points will it be applicable in the same script?.one again thank you very much, couple of weeks i am behind this. i will try the same and update you.
yes but in that case i would create a dyf for that python node so we have option for lacing and list level and should work…ps and with this one i shared you dont need ironpython…play around with it
yes. it works. but only a small issue after placing the fittings the both end pipes creates slope. i will have a detail check in the evening and sorry to disturb you, if you have time can you please give the other one, we have soil and waste pipe both run together. please help me i am really stuck in between a project. appreciate your quick response and thanks a lot.
not sure works great here;) “please help me i am really stuck in between a project” yeah isnt the forums fail…but more sounds your need hire a consultant…:wink: :wink: :wink:
