MEPover Element.Connectors can't use more.....Help me
Hi. Everyone…
and Mr.T_Pover…
Thank you so much for allowing me to work with MEPover Package.
The Element.Connectors node is not working suddenly, so I ask for your help.
Please help me with how to solve it.
I use Dynamo 2.04, Revit 2017. MEPover package 2020.06.02
Below is an error message.
Error: This input symbol is not currently valid, and cannot be saved until it is fixed. Valid inputs take the form:
name : type = defaultValue
The input name should be a valid variable name, without spaces. An input type and default value are optional.
Hi @MEP_Engineer ,
Welcome to the Dynamo community.
Try setting up the the name as element : var[]..[] as suggested in this post:
Thanks to answers quickly…
I did follow your mention but still can not.
As like below photo…
@MEP_Engineer It should be element : var[]..[] with only two dots (periods) in between and not 3.
Ok. I see…
It is must write lower case Alphabet?
I did write by providing Dynamo as like photo.
So… re Error
Try putting _MEPelement instead of element.
You can try with package DynaMEP, support ver 2.0 over
