Yna_Db
January 27, 2017, 8:13pm
4
See also this for the FamilyType.CompoundStructureLayers node:
Hi Dynamocando,
There is a custom node from “Clockwork Package” called “FamilyType.SetCompoundLayerMaterial”. Try using that see if it helps. Below is an example of walls.
[SetCompoundMaterialLayer]
…and this for setting parameters (type or instance):
Having trouble accessing the instance parameters of the family through Dynamo. With the Element.SetParameterByName returning “No Parameter found by that name”. Please see screen shots below.
Any help would be appreciated!
[image]
[image]
You should find your way with this. Please remember that specific questions receive an answer most of the time on the forum, especially when they follow these basic guidelines
One of the main goals of the Dynamo community is to help others. One way to do that is by answering your questions. But to get the right answer, you’ll first have to ask your question in the right way. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions on how to achieve that. Do not think of these suggestions as rules and especially do not take them as a guarantee of getting an an…
