Hi, first i have never use a dynamo but its okay i will be able to manage. My question is i have made this family (Level Header) with two text boxes as it shown 1-F.F.L 2-S.S.L and I made this shared parameter with (yes/no) parameter what am asking is how to activate this? I mean the once user check the first option (the one with red the second image) will pop up and the once the used uncheck it will hide?
I think this is something you’re better off to fix within Revit itself rather than using Dynamo.
I don’t think Revit ALONE can do this UNLESS it’s a coding thing this why am asking, anyway thank for your time to reply
Unless I’m not understanding your request, it sounds like you just want a visibility parameter. A quick Google search should be able to help you set one up.
Try using node parameter value by name and feed the value with 0 or 1 to switch between Yes & No (Visible or not).
