Can't set a yes/no parameter with Dynamo
I’ve been working on a graph to set a yes/no visibility parameter on all doors that are creating in the existing phase to control the graphics of the door swing. It worked in a test project, but seems to fail somewhere when using it on a live project. What’s strange, is that the correct doors are showing in the list at the end, but the parameter is not being set. I am also not getting any warnings.
I tried creating a new project, and copying the same door into it. The graph runs correctly in this new project. The parameter naming is correct, and the correct doors are making it through, so I’m not sure where the issue lies.
Capture
Any help would be greatly appreciated!
Thank you!
I am just guessing here.
Try Element.GetParamterByName to retrieve the value by unticked / ticked maybe its just 0 or 1.
Thank you for the response! I used your suggestion to verify the set value, and noticed they were all set to 1, even though I knew some of them should not be. I then discovered there was a Project Parameter with the same name added to doors which was being used. I removed that parameter and the it works properly now.
Thanks for your help EzDoesIt!
just curious can you set the parameter with True / False or is it 1 / 0?
Thats why we need SetParameterByGUID @erfajo or a check somehow
The difference in existing doors and new doors is this
existing
new
in the family is a boolean switch to make the difference in graphics.
it must be a dutch thing yes
its in NEN10 which describes how a drawing should be made
with phases you can only toggle the whole family to be visible i think.
Let me explain why we need SetParameterValueByParameterGUID node.
People tend to copy elements from linked files, bringing in the parameters of the object they copied.
Now imagine what happens if the parameters came from a Shared Parameter file setup for IFC export for example. You end up with muliple parameters IFCExportAs because the element copied was made from another SP file (same parameter name, 2 GUIDs). Now i have to make a choice which parameter to fill with a value in the instance properties. Which one do i choose? And how will it affect my IFC file?
Most of the time we need to know if an element is existing or new.
Walls and Floors and other system families are important too.
Hi @erfajo,
The reason for the parameter was to change the symbol of the swing to a straight line, instead of curved. Of course, the phasing can change the graphics to be lighter, but not change the shape of the symbol itself. I am in Canada, this is a common convention.
I disagree on that.
If you study how phases and phase filters work together in demolition and rebuilding of buildings or parts of buildings in Revit and make sheets of all stages, you will find out.
@erfajo
“Phase Created” is not recognized as a parameter in Revit formulas, but perhaps my syntax is wrong. How would you apply this formula?
The Dynamo graph was to remove the need for users to review each door individually. One person can run the graph and it would set everything correctly. In this case, the phase does drive the visibility parameter, it’s just done through Dynamo.
@erfajo, I think we’re trying to accomplish the same thing. I did read what you posted, but the file you attached is corrupt and it wouldn’t open. It looks like you’re using dynamo to set an instance parameter based on phase of an object, which is what i am doing. I thought you were alluding to a method that didn’t require Dynamo.
I called the parameter “Existing Door” so it’s clear to other users what it is for. It serves the same purpose as your “Opening Angle” parameter.
Ah, yes 2.0 explains it!
We had to control more than just the angle, our symbols switch to a straight line as well.
Thanks for your help!
