Revit yes no parameters
Is there way to turn on and off yes no parameters via dynamo ?
You can use Element.SetParameterByName node for turn off or on to yes no parameter. you have to write 1 to turn on and write 0 to turn off
Hi Jigar,
Yes, It is possible. Can you please be more specific what type of elements your looking to apply yes/no parameter.
<b>I want to use it for sheets category.</b>
Problem is I got four different stages of project.
We used 4 different text on top of each other and we turn on and off based on phase.
Unfortunately we can’t get those on/off parameters in schedules because they are family parameters in sheet. If we can get in schedule then I can export in excel and put 1/0 and bring back to Revit to update label but unfortunately I can’t because of limitations of sheet category.
I know there is easy way to manage via label but I want to see how dynamo can fix this problem
Jigar, Below is an example how to access sheets label visibility parameter (on/off).
