I’ve tried to utilize the grid nodes from the Lunchbox package to sort of replicate the Great Court by Foster and partners, but I get this strange behaviour as seen below. Are there any geometrical limitation to the form itself that I’m unaware of? Or is it something else completely? Should mention that it is the same story whatever grid node I try.
The problem is that only one segment of the surface is being considered, in spite of there being only one surface?
Explode the lofted surface, you’ll get four surfaces. You should be able to work better with that.
yes, it is one lofted surface and only one “segment” is considered. The exploding worked by the way. Thanks!
Hi there I try to create a similar surface as yours. I am new starter working with Dynamo.
Could you share the script. I basically want to create a surface with selected profiles from Revit. Import them create a very similar lofted surface and the import them back in Revit.
Hi @Artist
Could you please drop some images of surfaces your trying to create.
