Hi All,
I have a series of lines that I have lofted I expected to obtain surfaces, however when i loft the curves I seem to retain a single surface.
I would like to retain the individual surfaces. Some help would be appreciated.
regardsDR6_grillage_Rev_A_WIP.dyn (35.0 KB)
Kulkul
2
Hi @Kenyon_Graham
Edit: Currently your joining curves and connecting to crossSections try connecting directly to crossSections.
Below is an another example how to use Solid.ByLoft with guide curves.
Hi Kulkul,
I almost got it, see attached def…I did it in grasshopper then tried to convert.
Simple things.
if you open up the def. my display was a bit funky, with half of it suffering from a white out.
Surface_Bridge_Rev_B.dyn (29.3 KB)
rgds
kenyon
