Constrain/Align Elements, Lines
I am trying to Align, and Constrain Revit Lines with Dynamo, like we are doing in Revit. But I dont find any nodes for “Align” or “Constrain”?
In Revit it looks like this:
Align:
Constrain:
Every help would be great
I have also the same kind of problem. Seems like no one encountered the problem of aligning 450 columns to grids for each floor. :slightly_smiling_face:
Hey,
Welcome to the community, I don’t believe the Revit ‘Align’ tool is exposed in the API, so Dynamo can’t use it.
There is an Align method exposed, but it is the Lock part ie. the elements must be already aligned.
https://www.revitapidocs.com/2015/b3c10008-aba6-9eee-99c9-7e05ace75796.htm
Some discussion here:
However, it is possible to extract the geometry of the grids and columns, do some maths, then move the location (and/or change rotation) to coordinate the elements.
Have a go, if you get stuck post your graph :slight_smile:
Good luck!
Mark
Hello Mark,
Thank you very much for your welcoming. I researched a lot about this topic and encountered the discussions you shared. I am good at Dynamo but not with Python so Revit API. I simply need to solve the “Lock” part after the alignment.
I tried something but it gives an error saying the NewAlignmentMethod needs 4 tokens (3 given). It would be great if you can help me to understand what I am doing wrong. I tried to add a “True” value as the 4th parameter then it says “TypeError: expected ItemFactoryBase, got FloorPlanView.” I just want to understand how I can make the method run properly. I am using the GeniusLoci package to get references of elements. Most of the examples are in C# and work fine with 3 parameters but in Dynamo Python with Revit API library, it is giving some kind of errors.
Here is my full script:
clr.AddReference("ProtoGeometry")
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.Creation import *
from Autodesk.Revit.UI import TaskDialog
# Import ToProtoType, ToRevitType geometry conversion extension methods
from Autodesk.Revit.DB import Options
app = uiapp.Application
options = Options()
options.ComputeReferences = True
options.IncludeNonVisibleObjects = True
dataEnteringNode = IN
view = IN[0]
ref1 = IN[1]
ref2 = IN[2]
b = ItemFactoryBase.NewAlignment(view, ref1, ref2, True)
b.IsLocked = True
OUT = b
This is what I am trying to achieve. I want to lock this column to the grid element.
Hello Mark,
I solved it. Thank you very much. Here is the final pyhton script.
    # Import RevitAPI
    options = Options()
    view = doc.ActiveView
    ref1 = IN[1]
    ref2 = IN[2]
    b = doc.Create.NewAlignment(view, ref1, ref2)
    b.IsLocked = True
    OUT = b
Great work :slight_smile:
Hello, could you please place this dynamo file here?
