List sorting and combining // multiple sloped panels in radial grid
What I am trying to construct are muliple sloped panels between radial placed horizontal beams.
Somehow moving and rotating a list with points did not work out so I contstructed a radial pattern (elevations, segments) based on curves and ended up with 3 lists (startpoint, endpoint and intermediate points) but how to sort/reorder the lists to make closed 4-point polylines as shown in red on the screenshot ?
First of all the points on the curve should be merged in the right order then a loop to create the closed polycurves, but how?
In a later stage negative offset + extrusion are applied
polycurve_2017v020.dyn (39.3 KB)
Maybe this?
Thanks, that looks really good; I definatly need to learn some more ;
And how to make a structural beam below/between the planes; I need to flipflop somehow the lists so I can attach a beam to it ?!
Your original question was answered by @jostein_olsen you need to start new topic for your second query. Thanks!
