Hi there,
I`ve been playing around with this script which seems to have one problem part - not being able to extract the maximum item from one of the sublists.
Anyone encountered this before? maybe there is a similar node in one of the packages?
Thanks loads!
Kristine
Seemsweird, can you try to convert to string before passing to List.MaximumItem?
that actually worked thanks!
though a bit of workaround to get everything clean afterwards…
maybe way too long, though here it is.
Looks like you’re experiencing a bug. What if you try applying List@Level 2 for the List.Maximum node?
it’s working on my side. what version of Dynamo are you using?
I’m on 1.2.1
Yes it was definitely a bug… which did go on for quite a while. even when I restarted, though now it seems to be working. New day new opportunities.
I am also in 1.2.1 version and now both MaximumItem and MaximumItem on L2 works !
So thank you all for suggestions!
Cheers!
