Hi All
very new to dynamo.
I was struggling how to extract items from a nested list.
so lets say, I have the below list, and I want to get all the odd item from each list.
ie I am looking for an end result of
[0]list
[0] 1
[1] 5
[2] 9
[1]
[0] 2
[1] 6
[2] 10
Many thanks
Peter
Hi Peter, here’s an easy way to do it (don’t forget to set the lacing of the takeeverynitem to longest !) . You can play with the offset to switch from odd to even indices.
Many thanks !!
I do have a problem tho, for some reason it doesnt work when use with list.create, but it works with code block ?? I got error message
Warning: List.TakeEveryNthItem operation failed.
Value cannot be null.
Parameter name: source
Any idea?
Much appreciated
That’s strange … I don’t get the same result (i’m on 0.9.1) .
I guess you can try with a list.map , but this time the lacing of the takeeverynitem node has to be set to shortest:
Many thanks, it was a bit strange. probably just a bug.
its good to know some work around !!
