List management/Level issue
Hi everyone,
I am looking for some assistance with a list management issue that I am having.
I have a script that places builders work at various intersections. The script also applies 3 parameters to the builders work for now, namely:
  • Diamter/width
  • Height/Depth
  • Reference level
The Reference Level is the parameter which I cannot seem to get applied to the builders work correctly.
In the image above, I am looking to get the reference levels to apply correctly. What I need to happen is the following:
  • Index 0 from list 0 of the List.Chop node needs to apply to each index 0 from the second level of the FamilyInstance.ByPointAndLevel node.
  • Index 0 from list 1 of the List.Chop node needs to apply to each index 1 from the second level of the FamilyInstance.ByPointAndLevel node.
And so on…
Hopefully the slightly messy image below better depicts what I tried to describe above.
I cannot transpose the list as this cause issues with the other parameters that I need to be added. No matter which way I try and do this, there is always 1 parameter which is not happy and seems to be in the incorrect order.
I have also tried feeding the level input the “Unchopped” reference levels to no avail. I have tried all combinations that I can think of with regards to lacing and list levels & I just cant get this to apply the way I want it to.
I also don’t seem to be able to use the SetParameterByName node after I have rearranged the list order, as the parameter I am trying to set is read only and needs to be set by this FamilyInstance.ByPointAndLevel node.
Please, any assistance will be hugely appreciated!
Any thoughts?
Thanks!
@mitchellpUDG9S I think I understand what you are trying to achieve. List comprehension in Dynamo is always tricky. Try the following:
  1. Remove the List.Chop node and replace with a List.Create node, structuring your list of Level elements into a single list.
  2. Use a List.Flatten node to flatten your list of points by an amount of 1 so that the data structure matches my image. You may need to use a list at level in the List.Flatten node to achieve this.
  3. Set the Lacing on the FamilyInstance.ByPointAndLevel to Longest.
Hi Pete,
Thank you so much for the advice! It worked perfectly!!
The only thing I changed was to not flatten the points list, as I actually needed the “Empty List’s” in there to get the correct level assignment for different pipes on the same floor. Then I applied your advice further down my script as well and everything fell into place.
Thanks again!!
One more thing I actually noticed…
After the first run my project looks like this:
As you can see, a lot of the families have not been placed correctly, they have been placed, but are floating above the crop line.
After the second run, everything falls perfectly into place:
Any ideas on what is going on here? And how to get it right the first time?
I’m glad that helped. As for not placing it correctly the first time, I cannot repeat that behavior in the sample model I made. It could be a number of factors, like the way the family was built or what you are doing with the families in Dynamo after their placement. If you share the family and script, I could help you troubleshoot further.
Thanks very much Pete!
I have realised what my problem was… Very much user related :slight_smile:
Thank you for taking the time, appreciate it!
