trying to select title block families by sheet number to change parameters
What is the error from the String.ToNumber block?
And the error at the filter by book mask as well.
Likely it can’t check if the results are greater than a number as the string to number fails resulting in a null.
Can you check to see if there is a null in the results of the && node by wiring it into a list.unique node?
Thanks man, just figured out it was nulls, got rid of it by using a string contains A to make sure its all the right sheet numbers
The parameter value for Sheetnumber IS a string.
You can leave it as it is, no need to convert.
Marcel
